CEM-1A51 Communication with SRS control module Signal
adryan
Year and Model: 1999
Post by adryan »
Hi, this is my first post in this forum.
I am the owner of a S80 1999 D5252T (tdi audi engine)
Car is in family from new, and 6/7 year ago, it began to show the message (SRS URGENT REVISION, or something like that)
I think never hapened nothing in the car for show this DTC, i check with VIDA, that this error dont show in the first 3 second of start the car, but after, always
I think the problem is in the SRS module, some people say that is a error from CEM, but i just have this error in whole car.
I checked the connector and visual wiring of the module, plug and unplug and clean the coonnector, and everything looks OK, i should to try to replace this srs module ( 50-60€ 70-80 $) , maybe problem is in other place, but no crash and no repairs in car that it can generates a problem in there.
You know what error vida should show if i repalce the module for a used from other car, if it shows an other code ****, with a coding of the "new" module it would be fixed.?
Can i coding with d5t5/ vdash or i just oficial dealer can do it this operation?
What would you do?
I hope you understand my english!
Thanks!!!
KidsV70 wrote: 16 Feb 2019, 12:00 OP,
I can corroborate on the SRS control module, and the DIM. I changed out my SRS module with one a year older (2002 V70 2.4T vs 2001 XC70) and got a communication faulty error (SRS-00D1, maybe?). I also tried a 2004 S50 DIM in my car ('02 V70 2.4T) and no dice. I didn't check VIDA to see the errors as I didn't have it at that time. My experience FWIW.
Best,
Bert
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Pull the center console and check the connector, wiring and power to the SRS module. It could be as simple as cleaning the connector.
Active
Past
