Popping from engine when turning crank by hand
sicknoto
Year and Model: 2000 v70
Has thanked: 5 times
Post by sicknoto »
Hi all
I am hearing a pop coming from around my exhaust cam area when I turn the crank by hand. It sounds almost like opening a corked bottle.
Thanks
Nicm
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
Do you have the spark plugs in still? I had a little pop and hiss when hand cranking my engine once, I assumed it was just the cylinders pressurizing a little and then releasing.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
sicknoto
Post by sicknoto »
No the spark plugs are out right now
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
What is the engine history? Has the timing belt been removed or loosened since it ran? Any other thing that may change valve timing?
sicknoto
Post by sicknoto »
I had to replace the tensioner and water pump
Do the timing marks for both cams and the crankshaft line up as required? If not, you can have valve to piston interference.
