1999 v70 Shaggkira hot start issue
Has thanked: 1610 times
Been thanked: 4065 times
Second occurrence of hot start problem August 239800
No firing after refueling on Thruway
Needed 5-10 seconds cranking with gas pedal fully depressed. Fired, then ran roughly.
Possibles. ECT. Fuel pump relay. Fuel pump
Fuel pump, relay all Original TBOMK
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
abscate wrote: 06 Aug 2021, 04:51 Second occurrence of hot start problem August 239800
Please tell us you always carry a spare relay in the glove box ?
Uh, ok.
foggydogg
Post by foggydogg »
abscate wrote: 09 Aug 2021, 13:35 Uh, ok.
But did the relay swap work ?
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
The fuel pump would also occur in cold start situations as well. Someone knocking on the fuel tank with a log or something should resolve the issue.
But you totally already know that anyways ...
As always, hard to diagnose if only intermittent.
1996 855 R,
2010 V70 D5,
