98 V70 AWD Power steering pressure hose
- befarrer
- Year and Model: 1998 V70 AWD
- Has thanked: 1 time
- Been thanked: 24 times
How hard is it to replace the power steering pressure hose, I'm assuming a real pain since it's one piece from the pump to rack. To make it easier, I have an AWD LPT so extra stuff in the way.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
05 VW Golf TDI
Have a good luck at the access to pressure side union fitting on the rack. If it isn’t pristine, then the subframe and rack have to be dropped to get to it.
It isn’t a crazy idea to cut the new pressure line and put a swage union into the old pipe if the leak is upstream near the pump.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Steve just wrestled with this issue, and he pointed you in the right direction. Getting a wrench of any kind on the flare nut is gymnastic, and if there is any rust at all, you are probably faced with the drop-the-cradle adventure.
Cutting the hose off flush with the nut and then using a six-point socket may work, but you will still need room to swing all those tools.
- befarrer
I should update, did the repair a couple weeks ago. It was pretty easy. I removed the power steering hose clamps and brackets that secure the hard line of the power steering hoses. The pressure line is the upper hose on the steering rack, easily got to it using a crowd foot and an extension. I thought I would have to remove a bunch of other stuff to remove the hose, but I was able to wiggle it out easily from both sides without removing anything else. Installed the new house and refilled the power steering. Took me a total of 2 hours. I did put electrical tape around the ends of the hoses to protect from damage and debris in the hose while fishing the hose in. Then installed the o-rings when the hose was in position.
98 V70 GLT AWD
05 VW Golf TDI
05 VW Golf TDI
- Has thanked: 2199 times
- Been thanked: 1851 times
Well done that man! I know who to call if I have an issue now!
Neil
Neil
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
My hat's off to you. I just dropped the subframe a couple of weeks ago to replace the lines. I thought it was tough to wriggle the lines in there even with it out. It took half a day to scrub all the accumulated oily muck off the subframe.
I really respect those who got those lines off with the subframe in place. I have failed at that three times.
I did learn a trick recently that if you remove the rear engine mount (one m8 bolt, one m8/10 nut ) and get the mount out of the way you can get a crows foot onto the line coming down from the front. Mine have all been seized to the point where a crows foot would not break them free before stripping, so I plan on hanging the engine , dropping the subframe in back for any ps line work
On any of my p80s , if I have have the subframe down for any reason I’m sure going to inspect thoae ps lines for corrosion
- 49 Replies
- 3889 Views
- 11 Replies
- 7482 Views
Last post by netasp
- 929 Views
Last post by VolvoChef
- 2436 Views
Last post by Blacklab467
- 1658 Views
Last post by cn90
