A/C... Yah I know..
xc90ish
Year and Model: 2007 Xc90 V8
Post by xc90ish »
2007 Volvo XC90 V8 4.4 with 102k miles
It's in great shape needs alittle tlc here and there but
My A/C ... Here's some symptoms
When started I sometimes starts cool or warm .
Sometimes if warm it can get cool...
Sometimes cool but then can go out .
It does get cold when it rain
The air coming out can get pretty humid
I've checked the pressure...it is at the red .. I've had the truck for almost a year now...
Any suggestions ?
I'm thinking of evacuating and refill the refrigerate, or should I save my money.
Great appreciate any advice .. I've had a few Volvos and pretty confident in my knowledge but I always like to hear a second opinion.. thanks
Masscomguru
Year and Model: 2010 XC90 V8
Been thanked: 16 times
Post by Masscomguru »
It’s the control valve in the compressor. Very common, very easy to replace. It’s about 100 bucks from your favorite online volvo parts dealer. Get the system evacuated, replace the valve and have it charged up again.
Has thanked: 1614 times
Been thanked: 4078 times
Check the clutch gap at the compressor. Too large, and you will get the cold-warm scenario
The store can gauges are notoriously inaccurate. Check with a manifold set to measure the low/ high ratio which will point to charge or compressor problems
Masscomguru
It’s a variable displacement compressor. The clutch wear in the V8 and 3.2 models is very minimal. The issue is that the control valve is not monitored so the brain thinks it’s sending the correct voltage to move the valve, the valve doesn’t move. I actually don’t believe that the breadclip/shimming trick will work with these compressors.
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
No solenoid clutch to bread-clip (or tie-wrap) on the V8 and 3.2 motors.
My bet's on the control valve as noted above, having done a replacement myself a month or so ago with excellent results (consistent cold air). PN is 31305844.
edit- typos
xc90ish
Post by xc90ish »
Omg thank you everyone ! I appreciate it greatly I'll try it and report results when I can. !
Love crazy Volvo ppl
ylwgto
Year and Model: 2009 xc90 3.2 R
Has thanked: 9 times
Been thanked: 7 times
Post by ylwgto »
just went through this. Was going to replace just the control valve, but the car has almost 130K so I spent $100 more and got a new compressor, installed it, had it recharged and now it is steadily ice cold.
2009 XC90 3.2 R-Design 150K
Masscomguru
On the V8 you need raise the engine or pull the radiator to get the compressor out..
ylwgto
Post by ylwgto »
Masscomguru wrote: 19 Aug 2021, 14:32 On the V8 you need raise the engine or pull the radiator to get the compressor out..
Missed the V8 detail!
maybe better to pull the controller without pulling the compressor if possible...
xc90ish
Post by xc90ish »
Question.. do I need to get the number off the compressor on the v8 still
