Wiring Loom Corrugated Tubing: does it do anything?
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Just general question, not unique to Volvos...
- With time/heat (usually > 10yr/100K), the Wiring Loom Corrugated Tubing is falling apart.
- I always replace it with new tubing. But I notice the wires themselves have very good plastic sheath and rarely breaks down...
- Let's say it is summer heat and the underhood temp after a hot run is 80C: with or w/o the tubing, the temp of the wire plastic sheath is 80C anyway..
The question is: for wiring loom that does NOT contact anything (no frictional contact)...does the tubing protect the wires at all?
Attached is a random photo from the web...
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Protects from abrasion, corrosion and hungry varmints.
Looks better then the underlying mess of wires.
Active
Past
firstv70volvo
Year and Model: V70 T5 2001
Has thanked: 52 times
Been thanked: 123 times
Post by firstv70volvo »
cn90 wrote: 18 Aug 2021, 16:29 Just general question, not unique to Volvos...
The split loom tubing is especially protective for the coil wiring and this is based on experience. The split loom tubing keeps individual wires grouped together and protected from getting pinched between the cover and the head. The split loom tubing in the head is also most likely to deteriorate first because of the higher heat. The wire insulation is tough but I did manage to damage insulation on a wire because it was pinched when I tightened down the cover over the coil wires.
Post by cn90 »
The cosmetic cover: I removed it and stored on garage shelf for the last 10 years...
This way heat is not trapped and I have quick access to ignition coils #2 --> #5.
Also, I can wipe off any spilled oil.
Basically that cosmetic cover is useless.
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
I recently vacuumed picked that broken corrugated plastic from the spark plug wells before removing the plugs, a real pain. I will not be putting the "VOLVO" cover as i think it traps heat and cooks the coils. For wires near the engine wrap new corrugated in scotch tape.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Does anyone have a decent source for a high quality version of this corrugated tubing? Many of the reviews I read about Amazon shipped products indicated some weren't very heat resistant and deteriorated too fast. Maybe something that can be locally sourced at a chain auto parts store?
Thanks.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
AC Delco makes a high quality split loom and you'll pay a lot more for it but its worth it. The stuff that you'll find in the hardware store or lower end auto parts stores will not stand up to the heat as well and break down quickly. That said, I don't know where to buy it anymore, probably at an AC Delco parts store if they even still exist, perhaps you could order it at the GM dealer.
2003 XC 70 (sold)
Has thanked: 1609 times
Been thanked: 4065 times
For those who remove the cover , how do you remember how many valves you have when your date asks you hard questions like that ?
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
cn90 wrote: 18 Aug 2021, 16:29 The question is: for wiring loom that does NOT contact anything (no frictional contact)...does the tubing protect the wires at all?
In the spirit of good housekeeping, I did re-loomed ALL electrical wires in our 2001 V70XC. It feels better each time I open the hood.
The dirt particles, heat, and moisture will eventually eat into the conductors' protective sheathing after loom is out of the way, causing electrical faults. Loom keeps the dirt and moisture away.
hu5ker555
Year and Model: 2008 S60, 2015 S60
Has thanked: 46 times
Been thanked: 18 times
Post by hu5ker555 »
darylrobert wrote: 19 Aug 2021, 02:47 I recently vacuumed picked that broken corrugated plastic from the spark plug wells before removing the plugs, a real pain. I will not be putting the "VOLVO" cover as i think it traps heat and cooks the coils. For wires near the engine wrap new corrugated in scotch tape.
Yes...always vacuum or blow out the top of the engine before beginning any work on the coil packs or spark plugs. Those little broken plastic pieces from a deteriorated loom can't be good inside the crankcase.
