1993 Volvo 850 GLT will sometimes start & run for a couple of minutes, then rough idle & dies. Sometimes will not start but tries to fire.
If I take the coil wire off of the distributor cap & hold the coil wire end just above the distributor connection (which makes it produce a "hotter" spark) it starts & runs great. As soon as I reconnect the coil wire to distributor cap the engine coughs & dies.
I try to use OE or OEM parts, usually FCP Euro, when replacing things but ignition coil & distributor cap are pricey. Don't want to fork out all that cash for one or both if not needed.
Any idea what is causing my problem?
Thanks
1993 Volvo 850...weird coil wire-distributor issue
- RickHaleParker
- Been thanked: 977 times
This sounds like a classic for us guys that grew up with electrical-mechanical cars.
Inspect the distributor cap for hairline fractures. You may need to clean the cap to make them stand out.
When the wire is in the cap the current leaks through the hairline fractures. When you pull the wire up the resistance increases enough that the leakage is insufficient.
Active
Past
Past
- RickHaleParker
I recall some guys would toss the old but still working cap and rotor in the trunk. As a precaution against getting stranded in the middle of nowhere.
Active
Past
Past
- Has thanked: 987 times
- Been thanked: 1075 times
Most of the time, poor running on a distributor engine is an electrical problem in the wires, rotor or distributor cap. Sometimes a coil will go bad, but not often. If it is old enough (yours is not) to have points and condenser, it took even more regular maintenance.
- 12 Replies
- 6539 Views
Last post by mrbrian200
- 362 Views
Last post by MrAl
- 10282 Views
Last post by LOB
- 19 Replies
- 4521 Views
- 2465 Views
Last post by codygrimm2
