4 Random MIL Code, Odometer and Cruise not working.
interace2
Year and Model: 2004 S80
Post by interace2 »
Hello,
I love this car and want to get it working well, I greatly appreciate any and all help.
2004 S80 T6 Twin Turbo.
I have some engine codes that come on and then go off.
When I fill the tank all the way up the car throws codes P0496 EVAP System High Purge Flow, and P0497 EVAP system Low Purge Flow. the MIL is ON at this point always. After driving down the gas level to just below half way, the MIL goes off and the codes go away. The car also is noticeably more responsive and faster with less than half a tank and no MIL.
Another problem occurs under boost. I will give it gas on the freeway to pass someone, and the boost seems to surge and then slow. It like its fluttering or boosting on, off, on, off, you can feel it like pulsing with speed and a slight inconsistent acceleration feeling. This only happens when I hold the gas down for more than a couple of seconds.
Also there a code that seems to always come up P0507 Idle Control System RPM - Higher than expected. I have no idea, or dont see any symptoms about this yet.
On the dash it has a warning "Brake Failure Stop Safely". However the brakes work OK. Code P0571 Brake Switch A Circuit is always on or pending. Red “brake” and yellow “ABS” lights illuminated.
Odometer is basically not working.. it will go up like 1 mile for every 100 driven. Cruise Control Not working.
Also when the AC compressor kicks on at a stop the car wants to lurch forward.
Thanks.
RickHaleParker
Been thanked: 977 times
Post by RickHaleParker »
Can you pump gas at full speed or do you need to pump it slow?
Reach up under the dash and check the position of the brake pedal switch. Have somebody stand behind the car as you do a brake light check.
Look for air leaks and blockage the the fuel delivery system ... such as air leaks around intake manifold, charged air pipe, which would also kill the boost, dirty fuel filter.
P0507 = ECM-951C Engine control module (ECM), idle air trim. Signal too high, B6294T
Diagnostic trouble code (DTC) information
Condition
The diagnostic trouble code (DTC) is stored if the engine control module (ECM) registers that the actual idle speed deviates from the predefined parameters.
Substitute value
None.
Possible source
Search the fault cause in the air supply and fuel system (air leakage, blockages, etc.).
Fault symptoms
Malfunction indicator lamp (MIL) lit
High idling speed.
Active
Past
interace2
Post by interace2 »
Gas pumping is normal. Brake lights normal operation.
Thank you for your reply.
