2006 XC90
210,000 miles
5 cyl turbo
AWD
I replaced the timing belt water pump tensioner and idler. I did remover the top and middlebox around the TCM ECM for more room.
When I went for the test ride the transmission barely got me home. the thing would go in and out of gear, downshift and sequel the tires, stall at a stop, and need more throttle than it should, and slam into gear from a stop.
I did buy the tool and removed it and reset it with no change in symptoms
there were 26 TCM codes I did not write them down, the next day rescanned and no codes are listed I did not drive it after the scan, as it probably would not get me home.
So after all that, the question is do, I send the TCM to XeMODeX
Daniel
Are these Symptoms of a bad TCM
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
I have been trying to look for it, but on one forum, there was a post about a Volvo independent asking for help. Almost same symptoms as you are describing with a T5. He went the route of replacing the transmission and had the same results. It ended up being a broken ground wire. I would check all the ground/electrical connections.
- SuperHerman
- Been thanked: 207 times
General rule of repair. If the condition was not there prior to the repair double check your work and areas that may have been disturbed. Masscomguru's suggestion follows this rule and is an excellent suggestion.
- 3157 Views
Last post by 2001downunderxc70
- 1134 Views
- 12 Replies
- 3043 Views
Last post by erikv11
- 7998 Views
- 596 Views
Last post by yabadabadoo1026
