Does anyone know if I can swap the engine from my 2004 S60 2.5t B5254T with a 2003 Volvo v70 2.4T B2544T?
It looks practically the same with dual overhead cams. Will the wiring harness work from the S60 or will I have to grab it from the V70?
Will i need to flash the ECU or will it be compatible without flashing?
If anyone knows.
Thanks
Engine swap compatibly. Need help!
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
i have a 2.4T B5244T-3 its not dual VVT only exhaust. wiki says the 2.4t b5244t-4 is dual so would need a ecu flash
BenS60
- Year and Model: 2006 Volvo S60 2.5t
- Has thanked: 1 time
Thanks for the info.darylrobert wrote: 29 Aug 2021, 06:55 i have a 2.4T B5244T-3 its not dual VVT only exhaust. wiki says the 2.4t b5244t-4 is dual so would need a ecu flash
I checked the 2.4t engine and I only have the exhaust selonoid
- 1211 Views
Last post by benpineapple
- 1268 Views
Last post by bmdubya1198
- 1508 Views
Last post by polskamafia mjl
- 1671 Views
- 12 Replies
- 2060 Views
Last post by veektor
