i have finally found the source of an annoying plastic tapping sound coming from the front bumper area.
I have found that the tab on the cover that is meant to slot behind the bracket tab near the headlight has broken off.
Has anyone attempted a bumper cover repair?, replacing the whole cover sounds a waste to me.
I want to avoid drilling a hole, what glue will stick to these (blue) bumper covers JB weld?
XC70 front bumper cover side tabs broken fix
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I found a piece of matching plastic (has to be exactly the same kind of plastic) and glued it in with a heat gun. Worked fine till winter, when it eventually came off after numerous heat expansion circles. In AU you may be fine w/o freezing temps.
- 1232 Views
Last post by yair
- 1440 Views
Last post by mcbrightful
- 1357 Views
Last post by mike:
- 767 Views
Last post by vtl
- 1118 Views
Last post by camjohns
