92 960 wagon trans problems,help!
Hello all,I am currently experiencing a real headache with my 92 960 wagon,I am having extremely bad shift flaring between gears 1-2(seems like it can’t decide what gear to be in).this problem gets worse the longer I drive it for.I had a local shop rebuild the trans recently per his suggestion,I also installed a new pnp switch.It is back in the shop now as still has the SAME trans issue
.no check engine lights on.it is a electronically controlled aisin aw30 4 speed auto trans.Any help/advice would be greatly appreciated!Thank you
- 1873 Views
Last post by dm635
- 576 Views
Last post by 3wagons
- 1288 Views
Last post by Fred Trotman
- 2852 Views
Last post by Brick850
- 1025 Views
