ATF change out
Mr. Detail
Year and Model: 2002 V70 N/A
Has thanked: 157 times
Been thanked: 6 times
Post by Mr. Detail »
I just re-read the instructions that came with my IPD ATF flush kit.
It speaks to removing the lower hose with green clip. I have a pair of ramps that I usually use for my oil changes so do you think that will help my cause? It seems hard to work on that from the top of the engine compartment.
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
I did it from the top using a technique called the "Gibbons method". It was very accessible from the top. Google it.
2003 XC 70 (sold)
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Save your time and do just 2-3 drain&fills. Rationale:
1. Only a part of ATF flow is directed towards oil cooler, everything else circulates internally, i.e. new fluid mixes with the old one
2. Cooler return line goes basically into sump, where your fresh fluid mixes with whatever is splashing there in sump
3. About half of the overall ATF volume is contained in torque converter, where your new fluids mixes with old fluid like mad
No point in messing up with Gibbons method. Just do drain&fill, a few times.
Mr. Detail
vtl, sorry for my dumb question here but can I assume correctly that what you mean by drain and fill is virtually the same as what I would do with a normal oil change. Loosen the metal plug for the ATF pan underneath, drain out so much and then just re-fill up top with that skinny funnel?
vtl
Post by vtl »
That's correct.
Has thanked: 1609 times
Been thanked: 4065 times
Blacklab467 wrote: 11 Sep 2021, 11:53 I did it from the top using a technique called the "Gibbons method". It was very accessible from the top. Google it.
The Gibbons methods AlWays gives me this visual….scene from driveway..
vtl
Post by vtl »
abscate wrote: 14 Sep 2021, 05:19 The Gibbons methods AlWays gives me this visual….scene from driveway..
Rarely I see a car mechanic going that deep into the engine. Must be a reputable pro!
Mr. Detail
abscate, if you are an empty nester how can you still be in a sea of estrogen? Haven't all the girls left?
Mr. Detail wrote: 14 Sep 2021, 09:06 abscate, if you are an empty nester how can you still be in a sea of estrogen? Haven't all the girls left?
Mr. Detail
vtl, after removing the ATF plug is there a aluminum crush washer that needs replacement or can I re-use the old one?
