Hi,
I'm just posting for posterity's sake and because this website has helped me a few times.
I have a 2004 Volvo S60 2.5T with 170K miles and it was difficult to start after sitting overnight. Usually cycling the keys a few times in an attempt to prime to fuel time would get it to start. It would stumble a bit, but eventually start. The check engine light would usually come on and P0089 would be stored. There were no other codes present. I used a screwdriver to press in the schrader valve on the fuel rail and noticed how little pressure there was. I figured the fuel pump was tired and ordered and installed the replacement. The symptoms were slightly better but not perfect. The P0089 code would still come back. I most likely replaced a part that did not need to be replaced. My next best guess was the PEM/fuel pump control module. My local U-Pull-It yard didn't have any S60's but they had other Volvo's so I used the list below to find compatible vehicles. I ended up pulling it from a 2008 XC90. The car starts and runs great now and most likely was the culprit all along. I hope this helps someone.
Volvo S60
2001 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2002 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2003 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2004 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2005 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2006 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2007 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2008 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
2009 Volvo S60 Fuel Pump Driver Module
w/ Metal Fuel Tank
Volvo V70
2001 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2003 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2002 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2004 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2005 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2006 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2007 Volvo V70 Fuel Pump Driver Module
w/ Metal Fuel Tank
Volvo XC70
2003 Volvo XC70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2004 Volvo XC70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2005 Volvo XC70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2006 Volvo XC70 Fuel Pump Driver Module
w/ Metal Fuel Tank
2007 Volvo XC70 Fuel Pump Driver Module
w/ Metal Fuel Tank
Volvo S40
2004 Volvo S40 i 2.4L L5 Fuel Pump Driver Module
2004 Volvo S40 T5 2.5L L5 Fuel Pump Driver Module
2005 Volvo S40 Fuel Pump Driver Module
2006 Volvo S40 Fuel Pump Driver Module
2007 Volvo S40 Fuel Pump Driver Module
2008 Volvo S40 Fuel Pump Driver Module
2009 Volvo S40 Fuel Pump Driver Module
2010 Volvo S40 Fuel Pump Driver Module
2011 Volvo S40 Fuel Pump Driver Module
Volvo V50
2005 Volvo V50 Fuel Pump Driver Module
2006 Volvo V50 Fuel Pump Driver Module
2007 Volvo V50 Fuel Pump Driver Module
2008 Volvo V50 Fuel Pump Driver Module
2009 Volvo V50 Fuel Pump Driver Module
2010 Volvo V50 Fuel Pump Driver Module
2011 Volvo V50 Fuel Pump Driver Module
Volvo S80
2006 Volvo S80 Fuel Pump Driver Module
Chassis: From 430121
Volvo XC90
2006 Volvo XC90 Fuel Pump Driver Module
Chassis: From 238089
2007 Volvo XC90 Fuel Pump Driver Module
2008 Volvo XC90 Fuel Pump Driver Module
2009 Volvo XC90 Fuel Pump Driver Module
2010 Volvo XC90 Fuel Pump Driver Module
2011 Volvo XC90 Fuel Pump Driver Module
2012 Volvo XC90 Fuel Pump Driver Module
2013 Volvo XC90 Fuel Pump Driver Module
Volvo C70
2006 Volvo C70 Fuel Pump Driver Module
2007 Volvo C70 Fuel Pump Driver Module
2008 Volvo C70 Fuel Pump Driver Module
2009 Volvo C70 Fuel Pump Driver Module
2010 Volvo C70 Fuel Pump Driver Module
2011 Volvo C70 Fuel Pump Driver Module
2012 Volvo C70 Fuel Pump Driver Module
2013 Volvo C70 Fuel Pump Driver Module
Volvo C30
2008 Volvo C30 Fuel Pump Driver Module
2009 Volvo C30 Fuel Pump Driver Module
2010 Volvo C30 Fuel Pump Driver Module
2011 Volvo C30 Fuel Pump Driver Module
2012 Volvo C30 Fuel Pump Driver Module
2013 Volvo C30 Fuel Pump Driver Module
2004 Volvo S60 Hard Start/Stall P0089
- 40 Replies
- 12794 Views
Last post by jonesg
- 728 Views
Last post by jonesg
- 14 Replies
- 2433 Views
Last post by br0dy519
- 1524 Views
Last post by rguzz
- 4596 Views
Last post by stickman776
