When I bounce the left front, I get a squeak with a clunk sound. It sounds like it is coming from behind the LF wheel, and, when I am in the car, it sound like it coming from under the foot well. I shook the engine and it is solid. I replaced the struts and they are solid. Visually, I can't see what it could be, but would anyone have an idea?
Thanks in advance
Still searching for the cause of a front end squeak
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
A squeak and a clunk? I would look at the spring seat and expect a broken one, that would be my best guess. How many miles?
2003 XC 70 (sold)
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
The sway bar is behind the wheels
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
The front strut assemblies are about 6 months old. Teh squeak reminds me of a rusty door hinge. The clunk sound happens after the squeak,. I went under the car and didn't see anything- I was originally think of subframe bushings but even though I had a bright light on them I didn't see anything wrong.. Maybe it could be the sway bar mounting brackets
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- SuperHerman
- Been thanked: 207 times
What you describe is usually the strut spring seats, as the sway bar end links usually just clunk.
Start by inspecting the spring seat - it may be it is not tightened all the way down. The funny star shape piece could be the culprit. Then make sure the spring is properly aligned with the strut - the spring ends are butted up to the end ridge. Also wouldn't hurt to make sure the spring has not snapped. Make sure the seat has not failed - maybe you got a bad one.
For the sway bar end link, as you can create the sound without the car moving, disconnect one end and push it aside. If sound is gone that is one source of the clunk, maybe the squeak. You can try tightening them first.
motormikeyman
- Year and Model: 2004 XC70 AWD
Similar sound was driving me nuts. Turned out the stabilizer link nut was loose on the strut.
'94 940 wagon, 220K miles- sold to a guy who then drove it to Oklahoma
'99 XC70 AWD, 210K miles- trans went
'04 XC70 AWD, 196K miles- still going strong
'06 S40 sedan, 150K miles- went with the ex
azureblue
Thanks - that is something I didn't look for. Back up on the jackstands it goes..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
My nuts are tight..
But this sounds like it is coming from close to the driver's footwell.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- 1138 Views
Last post by misha
- 1567 Views
Last post by BlackBart
- 178 Views
Last post by Blacklab467
- 15 Replies
- 2755 Views
Last post by volvofornia
- 1240 Views
Last post by 93Regina
