[98 V70 M56] Drivetrain slack
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Hello folks,
I've been driving a few cars that aren't my V70 lately, and that made me notice how much slack there is in the drivetrain of the old wagon :x It's a 98 V70 fwd with an M56 gearbox, so it has 850 style driveshafts (single nut instead of bolts)
Gear changes tends to be jerky because of that slack, but doesn't really make any noise.
All the engine mounts have been replaced recently and a visual inspection doesn't show any noticeable wear.
Clutch (Sachs 850R) has done 8000 miles, flywheel was converted to single mass a long time ago.
That leads me to believe the issue is either in the gearbox (unknown mileage as it has been replaced by PO) or the driveshafts (which looks like the original ones).
If there's any axial play in the shafts, should I be able to feel it by hand with the car on jackstands :?:
I have a spare set of driveshafts somewhere in the garage, might swap them in to see if that makes a difference
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Has thanked: 2205 times
Been thanked: 1852 times
I would be looking at the CV joints. Jack the car and support it. Lie under the car and rock the wheels back and forward and look for movement in the joints.
Goupil
Post by Goupil »
Got the car on jackstands today. I could feel some play in the RH joints, the LH felt solid but both gaiters were torn !
Swapped the spare LH shaft I had and it already feels much tighter to drive 8)
I'll order parts to rebuild a set of shafts for peace of mind later :)
Well done getting into looking at this before it became a big issue!
Good Luck with the re-builds.
Goupil
Post by Goupil »
Well, back to weird: I've changed the wheels and it somehow reduced the drivetrain slack even more :?: :?: :?:
Not complaining but I dont understand :oops:
Same wheel bolts, same torque, just changed the wheels :? Went from Titans to 16" steelies.
