Oil leak
Fiodor
Year and Model: 1997 V70 2.0 T5 AWD
Has thanked: 13 times
Been thanked: 9 times
Post by Fiodor »
Hello everyone !
As always, new post, new troubles :mrgreen:
I'm having quite a big oil leak nowadays, with the top of the gearbox being covered in oil.
Would I be correct in assuming this might be a bad cam Seal ?
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
Has thanked: 1609 times
Been thanked: 4065 times
You are left hand drive , correct?
Fir the gearbox to be covered in oil it is probably a rear cam seal , and possibly a turbo line, if it has a turbo
Fiodor
Post by Fiodor »
LHD for sure !
I did the turbo return line when I replaced the clutch (as well as the RMS), quite impossible to do with the angle gear in place.
It's quite bizarre since I replaced it one or two years ago but I'll check to see if it's leaking again.
Fiodor
Post by Fiodor »
Well, no leaks from both rear cam seals.
There's quite a pool of oil on top of the engine right below the turbo, I might have messed up the installation of the oil return line gasket...
