Speedometer/odometer issue
Bob Mazzi
Year and Model: S70 1999
Has thanked: 3 times
Been thanked: 4 times
Post by Bob Mazzi »
I am working on a 96 850 wagon. I have a strange, intermittent problem. Over the last few years I've occasionally had the odometer and speedometer not work. But, if I stop and power off the car and restart it, 99% of the time they come back. So, I'm thinking it's electrical. Perhaps a relay that's not latching when the car starts? Over the last few days, it's happened more often, and has worked for a while and then stopped while in motion. But, a shutdown and restart cures it. I'm starting to wonder if Microsoft was involved in the design. <G>
When this happens, the computer also does not register the miles and the displayed MPG goes down as if the car is not moving. But the other gauges seem to work fine. No ABS light, trans light or check engine light. Trans shifts normally, so I'm assuming the speed sensor is still working.
Has anyone else run into this? Am I right in thinking it's likely a relay? And if so, which one?
Other Volvo's
61 122s retired at about 300k
96 850 N/A Wagon 300k+
99 V70 AWD Wagon project
Teddy1975
Year and Model: 2007 V50
Has thanked: 1 time
Been thanked: 7 times
Post by Teddy1975 »
Hey Bob.
The speedo/odometer gets the signal from the ABS module. Do you know if your ABS module has been resoldered? It can cause all kinds of problems when it starts to go bad.
Current: V50 2.0D, 2007, 6 speed manual
Previous: 850 2.0L N/A, 4 door 1996 manual, 740 2.3L N/A, 5 door 1992 manual, and S70 2.5T 1999 manual
Bob Mazzi
Post by Bob Mazzi »
I have no idea. Car has 300 plus k on it now, but I don't know what happened before 230k. ABS light is currently off so I assume that it's currently working. Only light on is the traction control and I've never looked into that one.
Other Volvo's
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Tracs & abs share the same module.
Time to rebuild abs/tracs unit.
Usually...abs/tracs lights turns ON at the same time when fault code is stored in abs/tracs unit.
Never seen them turn ON separately on cars equipped with abs/tracs unit...unless tracs is disabled manually on the switch.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Bob Mazzi
Post by Bob Mazzi »
Well, I could have a bad switch. I've tried the switch, but not tested it.
Other Volvo's
