Headlight motor turn on automatic ?
laser
Year and Model: 2001 V40
Post by laser »
When I put in key suddenly the "Headlight leveling motor" turn on and continued so, I had to disable battery cable to stop it.
Then I put on battery cable and its normal.
When I put in key again the "Headlight leveling motor" turned on again and continue so I had to disable battery cable again.
I took away Headlight assembly and dry with hairdryer, but same problem.
What can be the problem, control unit for leveling motor or leveling motor or .... ?
Volvo V50, 2006
