Really filthy.
How do I scrape out the debris from the bottom of the pleats?
To deep for a tooth brush, screwdriver sems like it might puncture, and doesn't get the filth out of the screen.
Dipped it in gas to get the bulk of oily scum off of it.
Hard hose spray from the other side? But still very sticky & oily.
Does proper cleaning make it reasonably white again? This is pretty black.
Maybe too far gone to clean.
Cleaning a K&M permanent AIR FILTER
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
Throw it away and get an OEM filter. You won't notice any difference, and your K&N sounds pretty gross at this point. K&Ns seem to have a reputation for not cleaning as well and possibly fouling MAFs if you overdo the oiling. It's one of those companies that does really well with its marketing and hype.
By the way, the K&Ns start off a sort of maroon color, not white. Not sure that putting it in gas is the right way to clean them.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Has thanked: 2199 times
If it is that bad then chuck it out. Cheaper to replace or as suggested us an OEM version like MANN.
- RickHaleParker
- Been thanked: 978 times
Toss the K&N in the trash and go back to OEM. The K&N will shorten the life span of your engine by letting larger particles through.
K&N air filters are expensive gimmicks with slick and misleading marketing . Stop wasting your money on K&N.
Active
Past
Past
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 117 times
- Been thanked: 271 times
Agreed, lose the K&N and buy a stock filter.
2003 XC 70 (sold)
Buy one Volvo filter and the rest are FreeCP……
- 31 Replies
- 5873 Views
Last post by soulvoid1990
- 3603 Views
Last post by Blacklab467
- 718 Views
Last post by theWIFES_S70
- 1483 Views
Last post by misha
- 905 Views
Last post by darrylrobert
