Power steering line
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
Power steering line
98 V70 has a bad bad leak- it isn't spraying so I suspect it is the return line- do I have to drop or lower the subframe to repair this ??
- Has thanked: 1847 times
- Been thanked: 1710 times
Have you had a chance to see where about the leak is coming from? If it was the high pressure line I would have expected a huge spray that would quickly drain the system. Trying to recall which line runs under the engine near the middle of the car. Could it have got snagged on something?
- skloon
it is right in the middle and I suspect it must be the return as it takes a few days to empty- is was -6 this am so I am not looking forward to laying on cold concrete this am, I had a bad transmission leak that covered it up for a while, I will jack it up this weekend and take a peek- if I have to drop the subframe I will have to pay somebody to do this
- Has thanked: 1505 times
- Been thanked: 3817 times
You can do the return line by just tapping in before the leak and routing up to the reservoir.
That fitting in the rack can be horrible to Release, it’s soft alloy and rounds off.
Avoid messing with it if at all possible
- skloon
Sadly discovered it is the pressure line a little pinhole but there was a mesh over it so it just dripped- I replaced the rack 4 years ago so the lines probably aren't super tight but do I have to drop the subframe ???
- Blacklab467
- Year and Model: 2007 xc 70
- Has thanked: 114 times
- Been thanked: 263 times
You seem to be intimidated with dropping the subframe and yes you will have to do it. It's not a difficult task at all, just 2 bolts and six smaller ones for the plates. The rest of the job is just remove and replace the line. Use a floor jack to support the engine and remove the front right engine mount ( 2 bolts). You'll probably need to jack the engine up with the subframe dropped at the same time, this is not a big deal nor difficult. The key to this job is to give yourself lots of room and then it goes pretty smooth, jack the front end up as high as you can and use good jack stands. I needed Crowfoot wrenches to undo the pressure line at the rack. The whole job should take 3-4 hours if you take your time. Do not buy an aftermarket part for this repair.
Good Luck.
Good Luck.
2003 XC 70 (sold)
- Blacklab467
Understood. That might be an expensive bill. Don't scrimp on the parts for this job, make sure you get a Volvo brand part. I've been getting a lot of parts from Volvo of Toronto online, their prices are very reasonable.
2003 XC 70 (sold)
I also use Volvo of Toronto. Their prices include free shipping.
Worth trying a patch. Let line depressurize, scrape, acetone clean.
JB weld and clamp hose over hole?
