Hi I’m working on a big oil leak. It was coming from my exhaust cam and I see that the seal is spinning with the sprocket. It shredded the seal and now with this new seal I want to make sure this issue doesn’t happen again.
Thanks
Nick
2000 Volvo v70 b5244t exhaust cam seal
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
So you either added engine cleaner before oil change or you need a PCV job. There is almost no point in changing your seals if you didn't do the PCV job. That's because there is so much pressure from that stupid little clogged tube attached below the intake manifold that it is pushing on the weakest cam seal and causing the leak as a result. For me it was clogged long enough that you can put your finger around the bolt and see carbon on your fingers. Leaky cam seals are the most common problem from a clogged PCV.
- 1496 Views
Last post by iRenaissanceMan
- 602 Views
Last post by bskeels
- 1409 Views
Last post by jantt
- 1438 Views
Last post by shiloh51933
- 26 Replies
- 2735 Views
Last post by Kerpre
