Hello,
so, I am hearing about these solenoids, and they are 175$ USD . each.
ouch!
1998 v70 FWD GLT
any way to get a block off plate, and have the OD work automatically, and lose the manual function…like the 7xx and 2xx series?
if not, any other checks? like wiring or switches….low cost items , instead of blasting solenoids at this thing and hopefully it will be fixed.
and, will pulling trans codes point me in the right direction>? can I do that with a pocket scanner, or do I need to pay a. Volvo Stealership a diag fee?
thanks and stay tuned….. I am doing about 2500 rpms at 65 mph.
the W button on near the shifter is defe not working ( but the light goes on and off in the dash) the little arrow light.
oh, my speedo is not working(intermittent) and my track light is always on …do those items have anything to relate to the overdrive?
thank you fellas!
Allen C. aka Big Al
Overdrive not Working…. but little arrow in dash does on and off with the W button
- Oly850
- Year and Model: In acquisition mode.
- Has thanked: 53 times
- Been thanked: 22 times
Hey big Al I had this exact problem a it’s not that you think, at least in my case it wasn’t. I took of the multi pin connector on the transmission off and toned out the the whole connector for any continuity (shorts) between pins(holes in this case). Found several! I followed the thick black wire bundle covered with cladding that goes from above the drivers side headlight towards the passenger side of the car. I found several wires melted together and shorted. I separated them (carefully) and applied liquid wire insulation, a test drive showed that was the problem, wrapped it up, never had another problem, shifted fine afterwards!
Looking for a V90 to be my next Volvo, at the very least a T5.
2017 XC90 Inscription - My best Volvo by far, but Ex-wife departed & I had to sell.
2001 S80 T6 - rebuilt trans, head gasket, fixed & sold
1997 V70 - kid car, sold
1996 850 GLT - found under bridge, 2 year refurb project, commuter car, kid car, T-Boned - SIPS saved passenger. Totaled.
1997 VW GTI VR6 - exceedingly fast.
1971 VW Type II/231 - it was pointed out by management that the children would be killed in it.
Sufbug
- Year and Model: 1998 V70
- Has thanked: 2 times
- Been thanked: 2 times
Oly850----
Sent u a pm. Thanks.
Also...here are some pics with my revs rpms and my speed on Waze.
2500 is 68mph
3000 is 83 mph
Does that sound right? Like im in OD....or am I stuck in a lower gear even though I'm in drive, and I do hear 4 shifts ( I think ) when I'm accelerating from zero mph.
Thoughts?
2500 is 68mph
3000 is 83 mph
Thoughts?
1998 V70 wagon / 244,013 miles / purchased 9-25-2020
2016 Cadillac CTS4 / might be selling this
1979 trans am 400ci / 4 speed / t-tops / not selling this
- 1215 Views
Last post by oizdaman26
- 1124 Views
Last post by Vova585
- 1326 Views
Last post by anothersullivan
- 3478 Views
Last post by reeltapegone
- 2425 Views
Last post by T64me
