No cabin heat - 2008 XC70 Topic is solved
- MDK
- Year and Model: 2004 S60R
- Been thanked: 42 times
Hey all.. MDK here So, about a month ago I bought a 2008 XC70. This past Monday I tried the heat and there isn't any. No codes, the system comes on fan works but just blows cold air. What should I be looking for?
Reason: improved subject
pbierre
- Year and Model: T6 XC70s: '13 & '15
- Been thanked: 12 times
With the hood open and engine warmed up, locate the 2 water hoses that go through the firewall to supply hot coolant to the cabin heater. If water is flowing, the hoses should be hot. If they are only luke warm, that implies that a flow valve is stuck shut.
If they are hot, then that implies that there isn't air circulating through the heater core, which means a baffle (airflow valve) is stuck closed.
Pin it down to one of these 2 blockages as the 1st step.
- 14 Replies
- 809 Views
Last post by jonesg
- 733 Views
Last post by Kach
- 2299 Views
Last post by supebeal01
- 581 Views
Last post by MarcM
- 26 Replies
- 5476 Views
Last post by dejanaleksov
