1998 s70 T5 vacuum lines on snorkel , function?
Has thanked: 1609 times
Been thanked: 4065 times
Working on a T5 m56 πŸ˜€ and I have two open vacuum stalks on the snorkel
One has a short piece of white hard pipe and dives down towards the fuel pressureregulator
The other is open
Can anyone help with functions ??
Pictures , and foggy red chairs
It looks like one side is an FPR Vacuum and the other is a purge vacuum source
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Yep.
Those rubber elbows are looking not a day over (or under) 23!
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Clearly the open port should connect to the right red chair. This will put you back in the drivers seat.
volvolugnuty
Has thanked: 2198 times
Been thanked: 1851 times
I have gone down to check on the 'R' as it should be similar if not the same. Problem is that the 'boss' keeps disappearing with it while I am home! :roll: :lol:
Now remember all those pictures you took while you were taking stuff apart so you wouldn't forget where stuff went...........!
volvolugnut wrote: 09 Nov 2021, 11:56 Clearly the open port should connect to the right red chair. This will put you back in the drivers seat.
volvolugnuty
I got my foggy and my luggy mixed up.
Chairs are for lugnut!!
