I have 1999 Volvo V70 Weird thinks happened to this Car ,I can not put in drive from Park, Don't have any error Code, Work only in cold weather have to do with Temperature ,Somebody can tell me with switch sensor I have to replace .
David
Hello Forum
- Has thanked: 1613 times
- Been thanked: 4077 times
Good morning David
This is probably a key switch sticking problem that is stopping your shifter from operating correctly
Try the little over-ride button on the console to see if that helps
Dimi2233
- Year and Model: 1999 V70
Thanks A Captain in a Sea of Estrogen ,It's Neutral Safety Switch, It's inside of Automatic Transmission Selector Box
Have a coil When it's hot do not want to work, I have to replace it
David
David
- Has thanked: 2215 times
- Been thanked: 1853 times
I am not sure you got what abscate was saying. There should be a small push button just to the right of your gearshift lever. It should have 'SHIFTLOCK OVERRIDE' written by it. If you press this at the same time as moving the gear lever it will allow you to move the gearshift.
Coil failure is not un-common with the age of these cars. If you are planning to use used ones, check under the rubber boot for cracks in the plastic of the coil body. They can run in this condition but they will fail again.
Ok. Well at least I am clear on that now! LoL!!
It’s a Hourse in Canada
Neil
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Fascinating thread ... Reminds me of that movie Lost in Translation.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- 1436 Views
Last post by Jeff Schubert
- 985 Views
Last post by Alabamabricklover
- 1679 Views
Last post by Ozark Lee
- 12 Replies
- 2609 Views
Last post by mika
- 846 Views
Last post by PS78
