Where to put new tires...front or rear
2006 XC70. I have uneven tire wear on two tires (left rear and right front). OK...needs alignment and some parts. That aside...I will be getting two new tires tomorrow. All tires will be off and balanced...then...Should I have the new tires on the front or rear? My gut says...Front...put the new ones on the front, as they wear faster... Thoughts?
- chris11211
- Year and Model: 2006 s60 2.5T
- Has thanked: 7 times
- Been thanked: 29 times
Is your car AWD? If it is you know you're suppose to change all of the tires.
Otherwise, everyone in the auto industry said that the good tread must be in the front. Volvo, however, in their infinite wisdom said that the better treads should be in the back.
- Has thanked: 2200 times
If you have an XC70 and the AWD is working then if you want it to stay that way you have to buy 4 tires unless the 2 old ones are virtually brand new.
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
For reference, Costco Tire Centers always put a single new set on the rears, even for front wheel drive cars.
...I always assumed you put the new ones on the front since they get the most wear.
- RickHaleParker
- Been thanked: 978 times
The front tires carry the weight of the drive train ... better traction. The light rear end is more prone to lose traction and fish tailing. That why the better pair of tires goes on the rear.
Active
Past
Past
TisMe
- Year and Model: 2001 & 2004 XC70
- Has thanked: 41 times
- Been thanked: 17 times
And somewhat irrelevant, if you're sporting a RWD and only swapping two tires, you'll want the fresh tread on the rear.
...but I'm not certain this is relevant to any Volvos
More relevant, Volvo switched their AWD systems from a good ol' viscous coupling to the Haldex in 2002 (as jonesg pointed out). My P2 XC70 actually has the viscous, a neat little artifact of the first year of their XCs. Had great experiences with it in several inches of snow. Less intelligent of a design however so I would never mix treads between the front and rear.
- Has thanked: 311 times
- Been thanked: 817 times
Yeah, the 06 XC70 should be able to mix tread depth without worry.
If you put the new ones on the rear you are always chasing your tail and unable to rotate the tires poprely: fronts start more worn and wear faster means they will never be suitable to move to the rear. So you will never have all four matched tread depth and more likely to get non-uniform wear on the fronts. It's a hassle for rotating, or for buying new tires as a set (which is preferred).
I'd put the ones with most tread on the front until all four wear down to the same level. Then run a four wheel tire rotation until it's time to replace the whole set.
