Happy Thanksgiving/ Holidays everyone!
Has anyone ever repaired/improved the door lock assembly on a P80 Chassis Volvo?
Mine is starting to stick, and worse, not locking over the striker.
EXAMPLE: I open the door, and as I'm sitting in my seat, getting ready to go, and close my door, the door closes, rebounds off of the door frame, and just..... Doesn't stay closed. After a follow up door closing, the latch catches the striker, and all is fine.
I don't want to spend $300 this close to the holidays. Has anyone repaired one of these? Any help will be appreciated!
Otherwise, have an awesome week!
Door lock assembly repair
- RickHaleParker
- Been thanked: 980 times
Sounds like the Door hinges are getting worn and need some adjustment or replaced?
Active
Past
Past
- Has thanked: 1613 times
- Been thanked: 4077 times
Try a shot of silicone spray up into the door striker pivot.
A 3.14 second blast using the red plastic wand.
They can break , so a junkyard solution will be 1/10 new cost
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
That's an oddly specific spray time.abscate wrote: 22 Nov 2021, 04:44 Try a shot of silicone spray up into the door striker pivot.
- ZionXIX
I wonder if he eats the pie in 3.14159 seconds
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Well we know he does get a bit pi-eyed over Nautic Blue 99V70's.
But I think I'm straying from the OP's lock problem. Unless it's jammed up due to......
1999 V70 GLT
1999 V70 GLT
- Has thanked: 987 times
- Been thanked: 1078 times
I am going to say some lubricant and a slight realignment may fix the latch. The striker plate on many cars are adjustable if you loosen the mounting screws to the door frame. Only a very small adjustment will be needed. Try moving down first, since the door has likely sagged. Mark the original position closely BEFORE you loosen the screws.
- 3508 Views
Last post by nickbw898
- 1495 Views
Last post by joevar
- 1648 Views
Last post by Clemens
- 18 Replies
- 7633 Views
Last post by sleddriver
- 1355 Views
Last post by BEJinFbk
