I connected the 2005 XC90 to VIDA, with the VIN#, the vehicle profile was all found.
However, in the Diagnostics, the Fault Trace tab is grayed out, the tool cannot read the car.
What's going on?
Cheers.
Fault Trace Not Enebled In The Diagnostic Tab Topic is solved
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Oka
Just to test, I connected the 'regular' OBDII tool (Innova 3100a), it read the XC90.Oka wrote: 24 Nov 2021, 15:55 I connected the 2005 XC90 to VIDA, with the VIN#, the vehicle profile was all found.
What's going on?
Cheers.
I thought maybe the plug under the dash may have an issue; but the plug is ok.
Any advice?
Cheers
Oka
Found the culprit!jgadbois wrote: 26 Nov 2021, 20:23 On mine I have to manually select the transmission type and click OK to get to the diagnostics
I went back to VIDA to check the settings. The wrong region (Partner group) was showing.
As soon as I selected the correct region, Bam, Fault Trace got highlighted under the Diagnostic tab.
So, all is fine now.
Thanks all.
- RickHaleParker
- Been thanked: 979 times
There is a difference between US VIN numbers and the rest of the world. In the US the 9th digit is a Check digit to validate the VIN number. The rest of the world, the 9th digit is the gearbox.Oka wrote: 26 Nov 2021, 21:38 Found the culprit!
The check digit was suppose to be for security as a guard against fake VIN numbers. Kind of silly now days because the algorithm for the 9th digit has been cracked and well known. Creating a fake VIN that will pass the test is easy.
Active
Past
Past
Oka
Found the culprit!
Thanks all.
Thanks all.
