I have seen that to change diff oil you remove the fill plug and insert a small hose to suck the oil out, Sounds easy right! I'm having trouble getting a smaller hose in to bottom of the differential .
Any suggestions on why hose to use for this ? I'm using a 60 ml about 3 fl oz syringe with a small ( not what size) hose probably 4/5 mm
Changing rear Differential oil 2006 xc 70
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
Would the stiff clear vinyl stuff from a hardware store work, so it would hold its shape?
