Fault Trace Not Working
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Maybe someone here might have answer to this - Fault Trace Issue.
https://www.matthewsvolvosite.com/forum ... 43#p588043
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Have you used this combo before, software and Dice tool?
Try it with the car running, the voltage is stably in range that way, see if it helps.
Oka
Post by Oka »
erikv11 wrote: 25 Nov 2021, 12:17 Have you used this combo before, software and Dice tool?
Yes many times in the past, I have. I have used the combo in the two 01 XC70s.
Though two times back, I noticed the the two 01 XC70s "kept" the same database.
The current reading keeps showing as the reading for any profile I selected.
I think I used it with the car (XC90) running, I always do with the XC70s, to keep the battery juice.
Besides the Fault Trace, what else can I try to see if the car is really connected?
Oka
Post by Oka »
Oka wrote: 25 Nov 2021, 12:04 Maybe someone here might have answer to this - Fault Trace Issue.
Found the culprit!
I went back to VIDA to check the settings. The wrong region (Partner group) was showing.
As soon as I selected the correct region, Bam, Fault Trace got highlighted under the Diagnostic tab.
So, all is fine now.
Thanks all.
