Installed a windows 10 direct install a few months ago. It was working perfect but I'm not sure what happened but now it doesn't pick up my DiCE. When I go to chose communication tool it shows the following: Maxiflash VCMI, VCI, Elite / Pro, Bluetooth, JVCI. Before it used to show my Dice so I'm not sure what happened. Any ideas? I am using the Roxy edition.
Thanks.
Should I just delete and reinstall some other version ? Or is this fixable?
On the VIDA DVD look in X:\3PP\Products\DiCE\ for the DiCE setup which will install the standard DiCE drivers.
It is possible that you got one of the oddball clones that uses a non-standard driver. We have seen them a couple of times. They only work with the "edition" that came with them.
Active
Past
