I'm looking for recommendations for an engine support bar in order to work on the steering rack of a 2004 XC70.
Are two-position supports like below OK and perhaps with some advantages like access from above? Any recommendations specifically for the Harbor Freight or other brand support?
https://www.harborfreight.com/1000-lb-c ... 96524.html
Are three-position supports like below better or even required for some operations like asymmetric loads or anything that disconnects the front engine mount? Again, any specific recommendations?
https://www.amazon.com/Astro-5820-Engin ... SFRI&psc=1
https://www.amazon.com/OTC-1725-Chrome- ... B000QER3I2
Thanks.
engine support bar recommendations
- Been thanked: 4068 times
Ive got the Harbor Freight one in Albany - whats your timeframe? I can loan it out but need to dance around a potential steering rack job myself.
Thanks for your donations to MVS, enotslim
enotslim
- Year and Model: 2004 XC70
- Has thanked: 71 times
- Been thanked: 16 times
Thanks for the offer but I plan to buy one. They're not expensive and have many uses on many vehicles. Time frame is when I get to it. This car is nice to have but not essential. I commute by bike (or stay home).
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
I managed to get my engine crane on the household budget by re-boxing it as a shrub puller.
I have not figured out how to market the engine support bar for home use yet.
The HF one works great, buy with confidence.
Mine has done four PS racks and two clutches.
- Has thanked: 2203 times
For the P80 the 2/3 bar may not work as the slam panel is plastic.
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 44 times
I have one similar to the first link, its important to grease the threads
Don’t use S hooks with these, either. I almost found that out in A very costly way. Get some cheap shackles from HF or Lowe’s and buckle the engine up firmly
- Has thanked: 987 times
- Been thanked: 1075 times
Treat your lifting device selection with the same care as the jack stands. Both support heavy stuff over your work area. S hooks and dog chains are not safe for lifting. Pay more and be safe out there.
enotslim
Thanks to you all. On the HF tool the bar and footings themselves seem solid but I do have concern about the "V" that I assume is welded to the bottom of the threaded rod and the seemingly undersized chain. Seems like, as with most such things, redundancy can be the key to safety. My thought is to use the supplied threaded mechanism as a first line of defense but to add high-capacity (5,000-10,000 lbs) ratcheting straps running over the support bar and under the engine or stronger chain with D-ring shackles in the same position. And I will fit a support under the engine if space allows.
Now:
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
2004 XC70
Then:
1972 144
1988 240 Wagon
1998 V70 T5
- 3284 Views
Last post by alschnertz
- 10223 Views
Last post by SuperHerman
- 1370 Views
Last post by darrylrobert
- 1338 Views
- 2203 Views
Last post by kallekula
