Engine seized
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
New starter, new alternator,New radiator hose.
I'm thinking when my hose blew,she got too hot. I tried moving the pulley,no go.. am I Anyone know of a 94 850 engine out there for sale? Bc the pulley wouldn't move I'm right, right? Nothing more I can do right? πŸ˜₯
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
If you had the plugs out when you tried to turn the engine, you are likely correct.
Has thanked: 1609 times
Been thanked: 4065 times
How are you moving it? 24 inch bar amd a 30 mm socket?
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
loveMy850 wrote: 05 Dec 2021, 16:01 Anyone know of a 94 850 engine out there for sale?
Any RN B5234Tx would drop right in and run. Just use the 94 850 accessories. Swap out any VVT with the 94 Cam sprockets.
Engine data B5234T ( 1993–1996 Volvo 850 badged as 850 T-5 or 850 Turbo. )
Cyl. capacity: 2.319 cc
Cyl. diameter : 81 mm
Cylinder stroke : 90 mm
Compression ratio : 8.5 :1
Intake valve diameter: 31 mm
exhaust: 27 mm
Basic timing : 6 Β± 2.
Idling speed : 850 rpm
Maximum engine speed : 6200 rpm (momentarily 6500 rpm for 2.5 seconds)
Maximum boost pressure : 166 Β± 7 kPa at 5100 rpm (absolute pressure)
Active
Past
loveMy850
Post by loveMy850 »
Yes socket but using a torque wrench.and no I didn't have the plugs out. Oh my God Are you guys for real. Oh my gosh what to do, an assesories drive gear, is ...this is excellent news. Matthew, everyone is my knights in shining armor her. I don't wanna lose her,I'm not gonna lose her! I will do whatever it takes.and it's gonna take you guys. Thanks Soon much.
Chuck W
Year and Model: 97 854 T5
Been thanked: 340 times
Post by Chuck W »
loveMy850 wrote: 06 Dec 2021, 08:36 Yes socket but using a torque wrench.and no I didn't have the plugs out.
Still, it should move, even with the plugs in. It'll just be more difficult. (Unless it *is* seized)
loveMy850
Post by loveMy850 »
Ok...I got this bad feeling that's what's going on, there's still hope isn't there???? I'm going to try with the plugs out. Now you guys do realize I'm a woman right ( : I've done so much wrenching in my life,my Grandpal gave me that gift. Some things I have to have that physical strength, but whatever it is I that's an underlined I get it done! No offense.i love wrenching and my 850 is my baby.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
RickHaleParker wrote: 05 Dec 2021, 20:03
exhaust: 27 mm
OP do you know if your car has VVIS? Also I'm assuming this is a non-turbo car but didn't see that in the post?
Most (all?) 94 850s are plagued with VVIS intake which means the manifold ports are a different shape and won't match the ports on an RN head. So if you want an RN engine you can't keep the existing intake manifold which means you can't keep VVIS or for that matter the EGR (I think all 94s also have EGR), all of which would make the ECU unhappy.
So using an RN engine gets tricky here, seems you would also need the right intake manifold? Or perhaps a head swap but that is beyond practical. There are 95 850 intake manifolds with EGR but all VVIS manifolds have the square ports. Maybe you can adjust something to just run without the VVIS, there are some good posts about VVIS in the archives here if someone wants to search and read :). Then you only have EGR to deal with.
RickHaleParker
erikv11 wrote: 06 Dec 2021, 09:34 OP do you know if your car has VVIS? Also I'm assuming this is a non-turbo car but didn't see that in the post?
Searched the OP posting. He has a 1994 Volvo 850 wagon non-turbo wagon.
That would be one of these:
1. B5252FS ( 10 valve ) with Siemens Fenix 5.2 no V-VIS
2. B5254FS ( 20 valve ) with Bosch LH-3.2/EZ-129K and V-VIS.
If he just wants to fix it and cannot find a N engine. NA RN lower end with the N Head ?
Active
Past
Post by erikv11 »
Yeah as I mentioned, could swap the head too but that's getting overly complicated IMO.
