Cylinder order?
Mr. Detail
- Year and Model: 2002 V70 N/A
- Has thanked: 157 times
- Been thanked: 6 times
Just to verify what I have read from another post, the cylinder numbers on my '02 P2 run from 1 thru 5 going left to right as I face the windshield from the front of the car. Is this correct?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Yes, you are correct. However, in car talk terminology, #1 is on the RH side OF THE CAR.Mr. Detail wrote: 06 Dec 2021, 06:01 Just to verify what I have read from another post, the cylinder numbers on my '02 P2 run from 1 thru 5 going left to right as I face the windshield from the front of the car. Is this correct?
Mr. Detail
Is "car talk" terminology always as if you were sitting in the driver's seat?
- Has thanked: 311 times
- Been thanked: 817 times
#1 is always closest to the crank pulley. No matter where you or the engine are sitting. I guess that's "engine talk" terminology!
chrism
Yep. For instance, in the U.S., the driver sits on the LH side of the car. Hence, our cars are known as left hand drive cars.Mr. Detail wrote: 06 Dec 2021, 08:23 Is "car talk" terminology always as if you were sitting in the driver's seat?
- Been thanked: 4068 times
Correct. So the part of the steering wheel you look at, is the rear of the steering wheel.Mr. Detail wrote: 06 Dec 2021, 08:23 Is "car talk" terminology always as if you were sitting in the driver's seat?
There is a complication. When referring to engine parts, it is sometimes the case that the parts are referenced to the engine compass. This gets nasty confusing.
Guiltyabscate wrote: 06 Dec 2021, 17:57 ... When referring to engine parts, it is sometimes the case that the parts are referenced to the engine compass. This gets nasty confusing.
- 8786 Views
Last post by erikv11
- 22 Replies
- 1524 Views
Last post by jonesg
- 2864 Views
- 2174 Views
Last post by precopster
- 5610 Views
Last post by EanBarnard
