XC70 seats into 2004 V70
Faust
- Year and Model: xc70 2008
- Has thanked: 31 times
- Been thanked: 10 times
Are any XC70 seats a "bolt in" for a '04 V70? What I am thinking is seats from a '07 XC70, but that is not a necessity, they just happen to be available.
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
- RickHaleParker
- Been thanked: 979 times
2004 V70 and 2007 V70 are both Platform 2 ( P2 ). They will will fit.
V70 P2 2000 - 2007.
You got a 1967 Coronet. ... 383 , 426 or 440 ? My dad had a fifth generation Coronet. It ran like a bat out of hell.
V70 P2 2000 - 2007.
Active
Past
Past
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Wasn’t there a change mid 2005 in the V/XC70’s?
Years ago I had sourced newer seats but something prevented me from installing them in one of my 2004’s. I think the floor mounts changed & possibly the connectors on the underside/front. If foggy recollection serves me right I think it was mid 2005.
Edit: Oragex answered my query a while back here.
viewtopic.php?f=9&t=85259&p=470984&hili ... ts#p470984
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- Has thanked: 311 times
- Been thanked: 817 times
Yikes! This question is not one to guess on.
Seats are definitely not the same all the way across the P2 range. 00 seats will only fit an 00 (obviously), in addition to the 01-04 isolation.
- RickHaleParker
Skins interchangeable. I would think skins would be why he would want to make a swap.
I recall separating bases from seats. Not 100% sure if you can switch the bases but I think it is a good probability.
Active
Past
Past
- Been thanked: 4068 times
The CANBUS speeds changed mid P2 and I think the seats are module controlled on these cars. That doesn’t sound too compatible.
- RickHaleParker
It changed in 2005. That is when the P2 went from what we are calling the CEM-B ( 1999 - 2004 ) to the CEM-L and CEM-H (2005+)abscate wrote: 14 Dec 2021, 04:59 The CANBUS speeds changed mid P2 and I think the seats are module controlled on these cars. That doesn’t sound too compatible.
This can be done if one can switch the seat bases. Use the seat base from the 2004. Mount the seats from the 2007 on the seat base from the 2004. That the appears to be the current big question.
Or one could peel the skins off both seats and put the 2007 skins on the 2004 seats.
Active
Past
Past
- 724 Views
Last post by Tumbler510
- 531 Views
- 853 Views
Last post by SuperHerman
- 465 Views
- 875 Views
Last post by kahl
