850 Central locking reverse switch Topic is solved
manovlov
Has thanked: 672 times
Been thanked: 163 times
Post by manovlov »
Hy Buddies,
I hope you're all fine. I have a question.
I wold like to install a switch on the central locking wiring that could allow me to shut down all door, after starting to drive. I would like to install it on the right side of the steering wheel as shown on the board below.
Can someone advise me on :
  • what kind on switch may i use,
  • do i need to go across a rely and then, which sort,
  • where plug the power on to, on the wiring,
    • what should i do to be able to close or open the door from this switch ?
Thanks for advises
Manov
850 Dashboard.jpg (184.64 KiB) Viewed 1185 times
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Hello Manovlov,
I think you may need to explain what you want to do. Do you want to make a master door lock and unlock switch to control all the door locks?
I assume you want a more secure central locking system.
Has thanked: 2198 times
Been thanked: 1851 times
Does your car not already have a master switch for all the door locks? Maybe in some markets they didn't get them?
manovlov
Post by manovlov »
Hello volvolugnut, what's Up ?
My car as a central locking system. But if i want to feel secure, a have to push the door driver side pin to close all doors while driving.
I would like to have a button that could allow me to close or open the door without pushing the door pin with the arm.
Manov
Salut Neil,
Same answer that volvolugnut. On the Audi A2 of Miss Manov, 10 seconds after starting to drive, all doors close by themselves automatically. I don't want such a level of perfection, a simple double push button would please me...
Since your car should be pre CAN bus, I would think you could directly connect to the switch in the drivers door that actuates all of the other doors. Some testing should reveal if you need power on or off to lock the other doors. Then add a switch in the dash as needed. Get power if needed to the new switch from something that is only on when the key is on.
Others may have other ideas.
Good day,
Been too long since I owned an 850. So there is no master door switch on cars with central locking like on P80 V/S/C70's?
I am fairly certain the 850's had a electric window over-ride button, but again can't see it on an of the pictures I can see. I thought that one was part of the window switches in the center column.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
There is a child safety switch on side of each rear door to prevent opening while inside car
manovlov
Post by manovlov »
Hy Guys !
Ok thanks to all of you, and for the help.
i think i'm gonna pick up power in this area.
Manov
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
A locking switch is an OEM item.
Per the owner’s manual, it’s just
to the left of the steering column
on US spec 850’s.
https://www.ebay.com/itm/255283925791?f ... BM2uvB07tf
manovlov
Post by manovlov »
BEJinFbk wrote: 21 Dec 2021, 06:48 A locking switch is an OEM item.
on US spec 850’s.
Thanks so much for this information.
Manov
