Hi all,
I'm a new member and am sure this has been asked before so sorry in advance.
I have to replace my Xenon headlight assembly's due damaged (cracked lenses) and flickering but very expensive. I have a new set of Halogen headlight assembly's coming and wondering if I can just change them over. I understand from searching the internet that I will probably end up with bulb error message/light but I can put up with that.
My Xenon headlight wiring harness connector appears identical to my friends Halogen headlight wiring harness connector for same model 2006 XC-70 Cross Country. Will new Halogen headlights be just 'Plug and Play'?
For some reason was unable to attach the photos I have of both connectors?
Thanks for any advice.
XENON to HALOGEN downgrade 2006 XC-70 Cross Country
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
If the wire size looks the same and it's 12V you could just try it out. Make sure the fuses for the Xenon and Halogen have just a 5 AMP differential.
- 1353 Views
Last post by SheTriedIt
- 1324 Views
Last post by URDRWHO
- 1819 Views
Last post by doublebug
- 20 Replies
- 4694 Views
Last post by PapaHepcat
- 756 Views
Last post by precopster
