Hi all,
I'm trying to find a coolant leak in the engine bay, I know it's not coming from the heater core. What kind of UV dye is compatible with Volvo OEM blue coolant? Do I need to flush/replace the coolant after testing? And will the dye change the color of the coolant?
This is the UV dye I can get from my parts store:
https://www.cpsproducts.com/product-details/b483906/
Thanks!
Coolant dye - which one to use?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
what does it matter if you drain it anyway.Geevs wrote: 21 Dec 2021, 19:07 Hi all,
Thanks!
gonna have to drain the system to fix it.
You also need the uv glasses and UV light.
a common source of leaks is the expansion bottle, look for white chalky dust , the corners fatigue and will show tiny cracks.
- RickHaleParker
- Been thanked: 981 times
Head to the Kitchen and cook up some Quantum dots. Figure out the dilution rate by experiment. Then dope the coolant system with the Quantum dots at the dilution rate. Quantum dots diluted to the correct ratio makes a non-toxic trace dye.
Active
Past
Past
- 378 Views
Last post by JimBee
- 1980 Views
Last post by MDK
- 1669 Views
Last post by MIB
- 20 Replies
- 9872 Views
Last post by JimBee
- 20 Replies
- 14716 Views
Last post by 850oldschool
