Do I need to remove the exhaust manifold to remove the head?
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
On my 2002 Volvo v70 XC with turbo, I am removing the head to replace the gasket. However, to remove the exhaust manifold, I need to remove the turbo or push it aside to disconnect from the exhaust. I am having trouble with that. Can I leave the exhaust manifold in place, and just disconnect it from the head, and pull the head forward to get it off so the studs are not stuck?
2002 v70 X/C 288k miles
- Been thanked: 4063 times
There are raised bosses in the head that prevent lateral movement until it is lifted about 1-2 cm. Remove the three bolts from the drop pipe and then you can lift it up with turbo attached. There are pictures in the p80 forum of my recent build
- 02V70
A jack with wood won't be able to support the manifold since the drivetrain and stuff is in the way. I also don't have a cherry picker. Any ideas of how I would support it? Also how strong would it have to be and how much would it have to be held up?
- RickHaleParker
- Been thanked: 977 times
Options:
- 1. Cut a 2X4 to length, lay it across between the fender ( not on top of the fenders ), them use a ratchet strap to to pull the manifold up and support it.
2. Make a support bar out of a 2X4, a threaded hook bolt and some big fender washers. Use the threads to lift the manifold t and support it.
3. Spend $80 - 100 for a real engine support bar.
Active
Past
Past
- 02V70
When I was putting the head back on and maneuvering it to fit in the exhaust manifold, I scratched the head gasket and made a small gouge in it between a coolant hole and a cylinder. I have a new gasket coming. Would it be better to remove the studs, or the exhaust manifold so I don't have to put the head in sideways and prevent this from happening again?
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
Use the head gasket packaging as a protection, lay the cylinder head atop, aiming its exhaust studs into the manifold at the same time. Slightly lift the head from intake side and pull the cardboard out.
Just in case, blow the cardboard clean before using it.
- 2801 Views
Last post by dscheste
- 12 Replies
- 7240 Views
Last post by pgill
- 17989 Views
- 1056 Views
Last post by callahanoffroad
- 669 Views
Last post by and1one1
