Horn Got Disconnected, Now What?
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Took my XC90 to get remote starter installed. When the car was pulled inside the shop for them to start work, the horn started, was continuous until they unplugged the horn connections. This took them long since that was not expected. They connected it, and it started again. So now, there is no horn.
What should I do now? I can't remember the last time I used my horn; but I need it. What should I do?
Cheers
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf , it's for MY07 but you'll be fine.
Horn power comes from the CEM triggered by the steering wheel module (LIN bus). Zero idea what your install has done to make the horn stay on but the EWD may help point out the cause.
Good luck
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Keep one in the car while you fix it:
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
Do you have Vida and a Dice unit? The horn switch is connected to the Central Electronics Module, CEM, and the CEM controls the horn relay. It would be useful to know if the CEM thinks the horn is activated or not. That will help troubleshoot whether it's the input side, or the relay, or something else. It's conceivable that they got something mis-connected when they did the remote starter. Or, the security system may be trying to activate the horn. Good luck!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Oka
Post by Oka »
ggleavitt wrote: 05 Jan 2022, 10:19 http://vidaresources.volvocars.biz/ewd/ ... 998202.pdf , it's for MY07 but you'll be fine.
Good luck
Could not download the PDF due to potential securities. Is this file safe to download so I can disable my security systems to download it.?
Please, what is "EWD"?
Thanks.
Oka
Post by Oka »
Good luck
Am able to download the PDF, however, I am not an electrical diagram reader, am ignorant in that knowledge.
I had asked what "EWD" is, now I assume it is "Electrical Wiring Diagram".
Oka
Post by Oka »
xHeart wrote: 06 Jan 2022, 07:51 Keep one in the car while you fix it:
That's a good one; I will.
Thanks
Oka
Post by Oka »
Roger_850T wrote: 10 Jan 2022, 19:49 Do you have Vida and a Dice unit? The horn switch is connected to the Central Electronics Module, CEM, and the CEM controls the horn relay. It would be useful to know if the CEM thinks the horn is activated or not. That will help troubleshoot whether it's the input side, or the relay, or something else. It's conceivable that they got something mis-connected when they did the remote starter. Or, the security system may be trying to activate the horn. Good luck!
Roger
Yep I have the tool. What exactly should I be looking for?
Yeah, you already told me what to check, but could you be more specific, please?
Thanks
xHeart
Post by xHeart »
Oka wrote: 12 Jan 2022, 00:12 Yeah, you already told me what to check, but could you be more specific, please?
The Volvo EWD reference is a must have for us DIYers. Here is a use of "#page=46" in the URL to access and bookmark specific page; here is CEM page. Try this http://vidaresources.volvocars.biz/ewd/ ... df#page=46
