HVAC System - Blower
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
In the XC90, I am going to flush the coolant with Volvo coolant and replace with a Volvo thermostat. Sometime in the near future, I'll replace the Coolant Temperature Sensor, since it is hidden by the engine.
1. For the HVAC (blower), it takes a long time to heat up inside the cabin, and still, it will not be really hot in the inside. Hopefully flushing and replacing the TStat would help.
2. The blower knob is always set to the max (which is kinda loud). In my XC70s, I normally leave the knob to half way when our temps are very nippy. For the XC90, with the knob max position, the amount of air is like half way in the XC70. The cabin air filter got replaced last month. What would be hindering the air from gushing inside?
Cheers
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
chitownV
Year and Model: 2008 XC90 3.2
Has thanked: 15 times
Been thanked: 40 times
Post by chitownV »
Sounds like you already explored perhaps the blower might be the issue. The resistor could also be an issue. Depending on your mileage and usage, might be a good time to replace both.
As far as not getting hot in the cabin, is that an air temp issue or an air flow issue? If it's an air temp issue, the cabin temp sensor can get covered in lint/dust/dirt and it can also get damaged. Some people use a low suction vacuum to clean through the temp sensor screen (too much vacuum can damage the sensor). This issue is shared with the S60 and is well documented in their group.
Dirty sensor:
Temp sensor testing:
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
Oka
Post by Oka »
chitownV wrote: 08 Jan 2022, 17:19 Sounds like you already explored perhaps the blower might be the issue. The resistor could also be an issue. Depending on your mileage and usage, might be a good time to replace both.
Dirty sensor:
I will get to this as soon as possible.
Thanks for the information.
Cheers
Oka
Post by Oka »
chitownV wrote: 08 Jan 2022, 17:19 As far as not getting hot in the cabin, is that an air temp issue or an air flow issue?
At least, air flow is an obvious issue. At full blast, the air flows as if I would have it in my 01XC70, one-third way. True it's been nippy cold in Anchorage, Alaska, but not in full blast after the car has been running for a while, parked outside. Usually, the car is remotely started, runs for about ten minutes, then when driving, the blower will be set to the max so as to get some heat.
Cheers
