What gaskets need to be replaced when doing head gasket?
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
I am going to replace my head gasket, and I found a kit that includes many gaskets. However some gaskets I have not found while taking apart the volvo. It shows some of the cam gaskets twice while I only found one. They are circled in red. Do I need them, and what are they?
Screenshot 2022-01-09 112239.jpg (134.15 KiB) Viewed 564 times
Are there other gaskets I would need that the photo doesn't show?
2002 v70 X/C 288k miles
Has thanked: 1610 times
Been thanked: 4065 times
There are several variation on the cam seals so your kit includes seals that you don’t need.
You may or may not have banjo washersd4pemding on PCV
The two double Chamber gadgets are for the thermost housing. You only need one of these, the one that matches
The o-ring upper right is for the water pipe in the rear/ right side of engine
The two metal gaskets are for the two styles of manifold to drop pipe gasket
Don’t use those small valve stem seals, Volvo only , and only needed if you are doing a valve job ( which you should)
