My name is Steve, and I am a new member.
seh43
Year and Model: 2004 v70
Post by seh43 »
I have just purchased an 04, V70 wagon. It is a non turbo, 2 wheel drive, w/approx 138K miles. All the issues seem to be minor but I want things to be right. The key FOB works but the key just swings loose in the FOB. Is there an easy fix for this?
The car is quite dirty inside which will only requires elbow grease, and there is a section of the drivers seat back that needs to be restitched.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
seh43 wrote: 09 Jan 2022, 17:52 The key FOB works but the key just swings loose in the FOB. Is there an easy fix for this?
2004 V70 would be the switchblade key. You can get replacement Shell Cases. Just transfer the blade, electronics and the RFDI transponder which is the little glass capsule in the head part of the case. Be careful taking out and inserting the RFDI transponder. You can crack the glass, so work it, not force it. The hardest part is getting the spring back in.
Active
Past
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Fellow newbie here too. When I first got my 02 S60 it had a stitch on the drivers seat that let loose too. Local upholstery shop fixed me up while I waited...not perfect but did a good job.
08 C702.5T (sold)
The non-Swedes:
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Krons wrote: 09 Jan 2022, 21:16 Fellow newbie here too. When I first got my 02 S60 it had a stitch on the drivers seat that let loose too. Local upholstery shop fixed me up while I waited...not perfect but did a good job.
Can you name the shop? I might get some stitching done, just knowing a decent shop nearby helps.
Krons
Post by Krons »
erikv11 wrote: 09 Jan 2022, 21:48
It was a place in Urbandale, IA next to Blackford Shoe Repair. Pretty sure this was a furniture place...I see there is an alterations place next door that does leather jackets, maybe give them a try can't recall if that was it: Geysa's Tailors & Boutique
Sorry to sidetrack your thread Steve!
08 C702.5T (sold)
The non-Swedes:
br0dy519
Year and Model: 2004 XC70
Has thanked: 132 times
Been thanked: 126 times
Post by br0dy519 »
https://andrewpeng.net/cars/2006-volvo- ... key-repair
This is a great guide for repairing your key. I used LePage All Plastics Super Glue to glue mine back up once I confirmed it was working correctly. Replacement switchblade end on eBay is under $5. I used a dentist's pick to gently chisel/pry my transponder out of my fob. It worked great. But if you break it and don't have a backup, I've heard exorbitantly high quotations for replacing a key (I believe it has to be shipped from Sweden IIRC)
04s60 2.4
04xc70 2.5t
Has thanked: 1613 times
Been thanked: 4075 times
Its a $500 experience to make one of those chipped FOB keys for a Volvo Both the new key and the car have to be physically present at Volvo to enable the key to start the car, in short.
Krons
Post by Krons »
If you want a replacement key you may want to call around for quotes from locksmiths. There is an independent guy here in town that does some of the chip fobs for a fraction of the dealer price, and they work well. Even comes to your door.
08 C702.5T (sold)
The non-Swedes:
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2865 times
Been thanked: 1332 times
Post by matthew1 »
Our dear moderator Song wrote up this switchblade key fix: viewtopic.php?t=31639
Also -> Amazon link
Krons wrote: 11 Jan 2022, 18:37 If you want a replacement key you may want to call around for quotes from locksmiths. There is an independent guy here in town that does some of the chip fobs for a fraction of the dealer price, and they work well. Even comes to your door.
As long as you move the RF chip,from the fob to the new fob ( careful) this can work.
Locksmiths cannot program new fobs. Volvos security programming is extremely robust , perhaps best in industry.
