I have replaced both rear parking lights with new bulbs but the error still shows on the DIM. My DIM is very intermittent (possibly due to a dodgy solder job on the circuit board from factory) may this be a problem? Both lights are
Now working fine how can I reset the DIM? Thanks
Reset parking bulb failure warning after bulb has been replaced
- firstv70volvo
- Year and Model: V70 T5 2001
- Has thanked: 52 times
- Been thanked: 123 times
Detection of a bulb failure is determined by current draw( through a shunt resistor), did you use the correct wattage bulbs? LED type bulbs are lower in current and can cause a bulb failure message. Don't think the DIM problem would change the bulb failure message and there's no reset that I'm aware of. When the current draw is in an expected range the message should go away. When looking at the new bulbs, does the brightness look the same on both sides?Tobykeane wrote: 12 Jan 2022, 01:07 I have replaced both rear parking lights with new bulbs but the error still shows on the DIM. My DIM is very intermittent (possibly due to a dodgy solder job on the circuit board from factory) may this be a problem? Both lights are
- 25 Replies
- 13759 Views
Last post by wizechatmgr
- 32 Replies
- 5415 Views
Last post by draser
- 14 Replies
- 4259 Views
Last post by commandoNate
- 1384 Views
Last post by pdr1966sc
- 6783 Views
Last post by 850forum
