98-99 Alignment specs S70 V70? Topic is solved
Eddystone
Year and Model: 1967 Ford GT40 Mk IV
Has thanked: 63 times
Been thanked: 81 times
Post by Eddystone »
Seems to me that someone posted the exact factory alignment specs for these cars in the forum, and I saved them. Can't find them now, and a search here turns up six million threads. Anyone have them handy?
I've had my 98 V70 in twice and it still isn't done right. Not a mechanical or worn part situation.
All U.S. market models.
All running and on the road.
Eddystone
Post by Eddystone »
lexmia
Year and Model: 1998 V70
Post by lexmia »
From the Volvo VADIS:
For the 98 V70 Base Model, Auto.
Front:
Caster 3.35 deg +/- 1.0 deg. Difference between sides Max 1.0 deg.
Camber 0 +/- 1.0 deg. Difference between sides 1 deg.
Toe-In (total) 0.33 deg +/- 0.1 deg.
Rear:
Camber -1 deg +/- 0.5 deg.
Toe-in 0.1 deg +/- 0.2 deg
Trust Angle: Vadis states 15 degrees, which of course is a mistake. It should be 0.15
For the 99 V70 Base Model, Auto.
Front:
Same as for the 98
Rear:
Camber -1 Deg +/- 0.5 deg
Toe-in 0.07 deg +/- 0.18 deg
For the 98 S70 Base Model, Auto
Front
Same as for the 98 V70
Rear:
For the 99 S70 Base Model, Auto
Front:
Same as 98 V70
Rear:
Same as 99 V70
Has thanked: 1610 times
Been thanked: 4065 times
If you do the math on the angle, for those of us who align with string, it’s about 3mm of toe at outside edge of tire and 2mm at the wheel edge, best reference
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
The best settings for handling are 0.15 degrees of toe in in the front, 0.0 in the back, and factory recommendations everywhere else
abscate wrote: 07 Sep 2023, 02:59 If you do the math on the angle, for those of us who align with string, it’s about 3mm of toe at outside edge of tire and 2mm at the wheel edge, best reference
Keep in mind this changes slgihtly with different wheel diameters
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
