Help me identify this part- 2002 Volvo s60 2.4T
MaverickT883
- Year and Model: 2002 Volvo s60
I was replacing the ignition switch/steering column lock as it had frozen up and stopped working, and in the process of being a bit ham fisted, broke this cable. I can’t find a part number or name online. I’m not too familiar with Volvos, so I’m not even sure where to start to look. Any help?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Looks like the ignition/gear shifter interlock cable.
https://www.ebay.com/itm/115052851981?e ... Sw8hhhbdV0
Edit: I found that the key had to be turned on to Position I or II (can’t recall which) in order to disconnect and reconnect the cable. But if everything was all locked up and couldn’t be turned it could be that ham-fisted was the only way.
MaverickT883
That’s indeed it! Thank you, and yeah, it was completely locked up (seized in position 0). I tried cutting the old ignition switch open to get it out without destroying the cable, but i failed. It makes me feel a bit better knowing that I didn’t really have much chance at not breaking it. Now… on gotta replace it. Crap.chrism wrote: 12 Jan 2022, 13:13 Looks like the ignition/gear shifter interlock cable.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
If you're like me and nowhere near a dealer, Volvo Toronto has decent pricing and free shipping.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
chrism
I wonder how much hassle it is to R and R that cable. If you think there is little chance of your car getting stolen you might want to try some method of rigging the cable in a “permanently pulled” position and not worrying about reconnecting it to the ignition switch.
As far as the lock assembly goes, did surgery damage anything beyond where the cable attaches? The reason I ask is because even though your old one is all locked up they can often be fixed internally to work again.
- 2172 Views
Last post by Sommerfeldt
- 1376 Views
Last post by MadeInJapan
- 2372 Views
Last post by dconklin
- 726 Views
Last post by etf48
- 2242 Views
