glovebox issues
SirBrickWagon
Year and Model: 1997 Volvo 850
Has thanked: 7 times
Been thanked: 11 times
Post by SirBrickWagon »
so, recently i got my car working for the first time in a few weeks, maybe a month. only problem is that my volvo likes to throw another problem my way once i get one solved. my glovebox won't open. the glovebox is unlocked and it still just won't budge. maybe the cable snapped because of the recent extreme cold here in calgary, but i've got a few things in the glovebox that are super important, any advice is welcome. i do not have a drill and will not be drilling my glovebox open either.
1997 Volvo 850 Wagon (Non-Turbo) with too many problems to count
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
We had this problem long ago.....early 2000's? On a long trip, couldn't get the door open. I carefully used pry tools and finally got it to pop open, but did a tiny bit of damage to the fabric edge. I think I replaced the latch. Kind of a brute force solution.
It seems to me there's a preferable method instead of what I did. I'd have to search for it.
crlande
Year and Model: 240DL;850;S70
Has thanked: 1 time
Been thanked: 36 times
Post by crlande »
There is old thread. Involves taping the edges of box door to prevent tearing the covering, large amount of door bending which was doable, a hacksaw blade to cut the bars on latch, and then getting new latch parts. Did once, work slowly is my advice
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Mine is stuck, too. I've seen various threads on getting it open, but never having seen it open before the pictures do me no good.... I can't tell what I'm looking at.
Where is the actual latch on the door? I tried reaching in with a pick but apparently it was not long enough to find anything.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
SirBrickWagon wrote: 13 Jan 2022, 11:22 so, recently i got my car working for the first time in a few weeks, maybe a month. only problem is that my volvo likes to throw another problem my way once i get one solved. my glovebox won't open. the glovebox is unlocked and it still just won't budge. maybe the cable snapped because of the recent extreme cold here in calgary, but i've got a few things in the glovebox that are super important, any advice is welcome. i do not have a drill and will not be drilling my glovebox open either.
Spray some silicone grease with a nozzle tube into the key hole, latching area and any crack or opening that can reach the latch and lock. Insert key and turn it to lock and unlock position a few time. There is no cable in the locking
BlackBart
Post by BlackBart »
454cid wrote: 13 Jan 2022, 16:46Where is the actual latch on the door? I tried reaching in with a pick but apparently it was not long enough to find anything.
See #8 on diagram...
https://www.volvopartswebstore.com/show ... evel=24662
BlackBart
Post by BlackBart »
SirBrickWagon
should also mention i am very open to any jerryrig solution, i might just pry the glovebox open enough to scrape some fabric away and unscrew the latch. does anyone know what might cause this in the first place, or is it just as mysterious as the origin of an 850's oil leak?
SirBrickWagon
also haven't seen any videos on how to open the glovebox just by unscrewing it, just pictures. i could make one if all goes well.
454cid
Post by 454cid »
SirBrickWagon wrote: 14 Jan 2022, 08:49 also haven't seen any videos on how to open the glovebox just by unscrewing it, just pictures. i could make one if all goes well.
I think I saw some screws underneath the front edge of the dash under the door.... are those what you're referring to?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
