After a steering rack replacement on Blue Steel (‘98 V70 base) about a month ago and not driving it much since then, I had a few minutes of a crank, no-start situation in 11-degree weather.
Once the car was warmed up and I was on the highway, the steering wheel “locked” at a slight angle as I was merging. I couldn’t straighten it as hard as I tried and had to come to a quick stop on the median, just barely jutting into the lane.
The wheel loosened up again, and I drove to the shoulder, where I checked the reservoir, which was fine, and the underside, which did not appear to be leaking.
It temporarily seized again, but I was able to regain control by briefly turning against the direction I wanted to go in. The rest of the drive was fine, but it rattled me.
Did I have moisture in the system that iced up? Belt, fluid level and alignment were fine and nothing seemed to be leaking. Any ideas on what to look at next would be appreciated.
Steering seized after a rack replacement
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Wow, I have no idea, but I'm glad it didn't cause you to wreck. That would shake me up too.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Been thanked: 4064 times
I think you might need to give Cardone’s lawyers a call, the NJ AG might help , too.
koolhandluke
- Year and Model: 99 V70 305k 05 V70
- Been thanked: 2 times
That sure sounds like something mechanically binding up. I would think if it were strictly a hydraulic problem(frozen moisture, etc.) you would be able to overcome that with brute force. It's been awhile, but I seem to recall fully seating the steering shaft to the splined shaft on the rack was a bit of a challenge in tight quarters. I would start by giving the steering shaft(u-joints, etc) a peek. An internal problem with your remanufactured rack could also be to blame. I sure would like to duplicate the condition in the garage before I yanked it out again...Steve
We had a couple of Cardone racks lock up a few years ago. Fcp pulled it from sales. I’ll try find thread
Bruno , can you let us know rack make and source please?
brunocerous
Yikes. That doesn’t sound good.
I had my local indie shop source and replace it with a Cardone remanufactured rack.
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Same thing happened to me, on a new-to-me 99V70 a few months ago. When I finally got the subframe and rack on the floor (a whole 'nuther sporting event), it had a Cardone rebuild sticker on it. Mine isn't back on the road yet, but the old one is useful for its core value.
