2000 S70 just stoped turning over
Biff6996
Year and Model: 2000 S70
Post by Biff6996 »
Ok, my car just stopped starting one day, but leading up to it, it started to hesitate at times, then when I would turn the key, I got nothing not even the clicking, then if I kept turning the key eventually it would start. One day it stopped all together. I thought it was the battery, because I didn;t have the right size battery in it, it was too small, so i went and got a new one, the right size for my car, that didn't work, so then I got a Starter, put it in and that didn't fix the problem, then I got a new ignition switch, that didn't work. It's not the alternator, when I take the battery cables off it continues to run perfect. Now I am at a loss. I am a single woman and con not afford to take it to a Volvo Technician, I'm trying to do it myself, but nothing has worked. Please help. Also this all started after i replaced the radiator because of a crack. Please somebody give me some ideas i would so appreciate it and you. Thank you for your time. Beth
Has thanked: 1498 times
Been thanked: 3810 times
Morning Beth and welcome to MVS!
Is the car still exhibiting the problem of not starting or not cranking ( engine turning but not firing?)
Don’t disconnect battery cables while running, that’s really bad for things.
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Does the car have automatic transmission?
If so...then PnP switch might be bad.
Did you tried to start the car in N position?
You covered all things which would prevent the car from cranking...battery and starter.
Did the starter came as a whole replacement unit(brand new or rebuilt unit)?
Bad PnP switch will also prevent the car from cranking.
NEVER,NEVER disconnect the battery on a car with bunch of ecu(s)!
You will fry ecu(s)...if not allready!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jmcguire
Year and Model: 1996 850 Sedan
Has thanked: 19 times
Been thanked: 9 times
Post by jmcguire »
Starter relay or solenoid, maybe?
1996 850 Sedan
